What should go here?
mjsandbe wrote:
Contact K-GAP and order part #189, that's the gas pedal Bellows. Walt.What should go here? Right now, it looks like I have Duck Tape sealing my accelerator.0 -
walt's garage-53 wrote:Contact K-GAP and order part #189, that's the gas pedal Bellows. Walt.
And this is what you will clean up the bottom of the door with.
It also will take a lot of paint off. Can be obtained at Harbor Frieght,
or Lowe's, or Home Depot. The less flexible the hairs are, the faster the job becomes. Dave0 -
Soft rubber pad on the under side { my invention , helps keep cold/heat out }{ you can make one out of a sponge } and the bellows on top side . Don't get too wild on the wire brush , you can also remove METALL with it . BUD0
- 115 Hudson 1916 - 1929
