Grrrrrrrrrrrrr...Carb assistance
I have a Carter 2115 S that was on my car (1954 Wasp with Original 262
engine)..
I have been running a REBUILT CARTER 776 on the car for the past few years.
My question is this...Which of these Carbs is the correct one for MY specific engine or is there a difference. I have the 776 adjusted for best performance and I still show on the plugs that after very little use I am running rich on the mixture...
Plugs are a dark black and are dry
THANKS
TOM
engine)..
THANKS
TOM
Info I found--
1950 - 54 PACEMAKER 500, 4A, B,C, PACEMAKER DELUXE 50A, WASP 4D 749S, 755S CARTER WA-1
1952 - 54 4C, 5B, 5C, 5D Wasp, Super Wasp, 1C Jet, 2C Super Jet 990S, 2009S, 2009SA, 2114S CARTER WA-1
CK550
1952 - 56 (2 CARBS) HORNET 78, C, 7D, 35560, 35660 968S, 2113S CARTER WA-1
1953-56 1C Jet, 2C Super Jet 2013S CARTER WA-1
1953 SUPER WASP 5C 776S CARTER WGD
1954 HORNET 7D, SUPER WASP 5D 2115S CARTER WGD0 -
TOM-WA- wrote:
The difference is in the metering rods. The 776s has a little richer jetting. 776s meter rods #75-754----2115s meter rods #75-732 These must be set correctly. Base number stamped on bottom should be #771 Walt.I have a Carter 2115 S that was on my car (1954 Wasp with Original 262
engine)..
THANKS
TOM0 -
walt's garage-53 wrote:The difference is in the metering rods. The 776s has a little richer jetting. 776s meter rods #75-754----2115s meter rods #75-732 These must be set correctly. Base number stamped on bottom should be #771 Walt.
Walt..thanks for the info, but I am still confused....Can I use either Carb on my 54 Wasp 262 engine. It had the 2115 on it when I bought it and I changed it to
the 776.
I guess what I am trying to find out if I am using the right carb for my car0 -
TOM-WA- wrote:
You better have a 2115s rebuilt and install it on your car. Plugs being black is a sign of a rich gas mixture. They should be light tan. Walt.Walt..thanks for the info, but I am still confused....Can I use either Carb on my 54 Wasp 262 engine. It had the 2115 on it when I bought it and I changed it to
the 776.
Looking back over the application chart, why did the carbs change for the Super Wasp for 53 to 54 (776S vs 2115S ) ?0
Kdancy wrote:Info I found--
CK550
OK, this listing info leads me to some questions about the Super Wasp applications-
1- is the carter wa-1 the single barrel dual carb applications for some and single carb application for others with non hornet (308) engines? If so, what # is the dual carb application # for the Super Wasp?
2- Why go from the 776S in 53 to the 2115S in 54 for the Super Wasp?0 -
Kdancy wrote:
1954 Hornets-WGD 2 barrel-2115s----51-52-53-54 Hornets twins-968s or 2113s----52-53-54 Wasp and Super Wasp twins--990s or 2114s This is factory listing. With WGD 2 barrel you need 2115s Like I stated, 54 went a little leaner for more power. Walt.OK, this listing info leads me to some questions about the Super Wasp applications-
walt's garage-53 wrote:1954 Hornets-WGD 2 barrel-2115s----51-52-53-54 Hornets twins-968s or 2113s----52-53-54 Wasp and Super Wasp twins--990s or 2114s This is factory listing. With WGD 2 barrel you need 2115s Like I stated, 54 went a little leaner for more power. Walt.
Walt,
I just looked at the carb on my 53 Super Wasp and it is a 776S and is supposed to be the original carb. I ordered a rebuild kit for it from Daytona parts company, they just finished the 37 Terraplane carb restoration. I will post pictures when it comes in.0 -
OK, another person to ask a question.
I have a 308, S/N 185834 which I believe is from '52. I am running a 776S on it. I need to pull a plug to see how rich it may be running, but is this ok or should I be running a different carb?0
- 115 Hudson 1916 - 1929
