Exterior Sun Visor
[Deleted User]
Reference exterior sun visor see pcitures which Allen already painted and installed, view in/out emails exchanged between Allen and my self. My question to Forum am I correct in having under part of visor painted dull or black color to avoid Sun reflections? Also some additional pictures of progress, hope to finish car soon...:)
Thanks,
Ray
"Wow, Allen sun-visor looks good, quick question to avoid sun reflections from under part of visor what color will you paint? Also will you pant inner/backside of fender skirts black or with POR-15 or same as rocker panels.
Ray"
"Good evening Ray,
That is a good question about the under side paint color on the visor. I did not think about it and it is already on the car.
Hmm!! will have to look at it in the morning. Might have to take it off and paint it Black?? What do you think?
The rockers are all gray even back side.
Allen"
  • Ray
    The majority of the installed visors I have seen follows the manufacturer’s recommendation to leave the bottom side paint as delivered. Flat and green... Obviously this is the owner's decision. For me the reflection off the inside of the visor is distracting in the least and potentially something that could cause you problems driving.
    Pictures of progress are GREAT!
  • Ray, Ken is right. They were a dull green or a flat black in color. Were painted the same as the vent shades on the underside.
  • As always, thanks to both Ken & Bob for immediate input. Another question, as I purchased NOS visorwith new brackets included over two years ago with instructions; does brackets look correct for 1950-1953 models?
    Thanks,
    Ray
  • RonS
    RonS Senior Contributor
    they look right to me. Same as mine.
  • Thanks Ron, just wanted to confirm brakets are correct ones.
    Ray
  • russmaas
    russmaas Senior Contributor
    Woodgrain looks great
  • Thanks Russ, tryng to restore car with best possible attention to detail.
    Kindest Regards,
    Ray
  • Ray
    You asked the question...
    There were two different style brackets for the Hudson Visor. One set was for Stepdowns without stainless trim on the windshield pillars and the other is for vehicles with the trim.
    Brackets look pretty much the same... but the difference is the cars with trim require a deeper reach so are longer from the driprail clamp through the area that bolts to the visor. One method to distinguish is to observe the distance from the hole closest to the drip rail. For non trim visor mounts, this hole is very close to the drip rail clamp while the trim type mounts have a visible space between that hole and the drip rail clamp.
    Hope this helps.
  • Heart_Of_Texas wrote:
    Ray
    There were two different style brackets for the FULTON Hudson Visor. One set was for Stepdowns without stainless trim on the windshield pillars and the other is for vehicles with the trim.
    Hope this helps.
    Thanks Ken,
    As always your a wealth of supporting information...Also found visor instruction installation on best/yours complied web-site offered.
    Stay well,
    Ray
    Thanks,
    Ray
    Ray"
    "Good evening Ray,
    Allen"
    Flat green was original no matter what color was on top. Walt.
  • bent metal
    bent metal Senior Contributor
    I agree, the same color green that you show on your center bracket.
    Is your instruction sheet dated? Just curius.
    I'm not familiar with the "Fulton", I've only messed around with the "Karvisor". .....For whatever reason,:rolleyes:....they came out with two types. A short and then later a long bracket. The long bracket has a cresent shaped detail line on it. The earlier "short" bracket does not. That's what you have, the short with no cresent. 48-9
    That's my two cents.:)
  • To all,
    Thank you,
    Ray
  • Ray wrote:
    To all,
    Thank you,
    Ray
    Here is a modifacation you should do before you lock down the allen set screws. Cut 2 strips of 1/16 aluminum, 1/4 inch wide and 3 inches long, insert in drip rail where allen set screws will be locked down, and now you will have a solid hold on the drip rail. I can drive over 90 per and visor does not flap. Walt.
    Thanks,
    Ray
    Ray"
    "Good evening Ray,
    Allen"
    Repainted pictures of visor and some others; rain shields I purchased from Walt will be painted same as visor...
    Ray
  • Thanks again for sharing ... nice work!
  • essexcoupe3131
    essexcoupe3131 Senior Contributor
    That's a fine looking vehicle, coming along really nicely,I have a similar colour in leather that I am doing the coupe in and I currently have yellow trim inside around the window frames and a friend of mine is trying to talk me into wood graining them all and I was going to paint the same color of the leather,
    Posting this thread gives me a very good prospective on it all, though they are totally different style of vehicles
    Looks pretty cool
    Well done
    Mike
  • ESSX28-1
    ESSX28-1 Senior Contributor
    Surely Mike, a man of your woodworking skill & experience would find it easier to use a real vaneer!!:D:D
  • Wow Ray! Everything looks great. Are you gonna invite me down to Vegas to go for a ride in that beauty when it's all done? LOL
    Thanks Dave,
    Getting closer...Any time and any one else who's visiting Las Vegas.
    Ray
