Oil pressure sending unit
ski4life65
Anyone have a part # for a oil pressure switch (308)? I know Dave K. has them, but sorta need it yesterday.
Thanks
Don
Thanks
Don
Napa OP 64150
While we're here what is the best and correct place to screw in the oil pressure switch?
Thanks,
Jeff in kelseyville, Ca0 -
Put it in the pipe threaded opening in the block Just above the oil pump. You should use a short extension and a 45 degree angle fitting to keep it away from the exhaust manifold.0
- 115 Hudson 1916 - 1929
