Second clutch fluid plug?
Changing the Hudsonite in prep for Spokane. I am putting in new spark plugs anyhow, so took them all out, which makes it easy to turn engine with socket on front crankshaft bolt. Got the plug lined up, stuffed the rag, got it out fine. Then turning to find the "star" on flywheel (meaning opening is at bottom for draining). Didn't find the star, but found what appears to be a second plug. Looks exactly like the one I took out. What's the story on that???
Keep turning until one plug is in opening for filling and other plug will be at bottom.
Mike (WA) wrote:Changing the Hudsonite in prep for Spokane. I am putting in new spark plugs anyhow, so took them all out, which makes it easy to turn engine with socket on front crankshaft bolt. Got the plug lined up, stuffed the rag, got it out fine. Then turning to find the "star" on flywheel (meaning opening is at bottom for draining). Didn't find the star, but found what appears to be a second plug. Looks exactly like the one I took out. What's the story on that???
Hudson (over) engineering - makes it easier for those who can't find one plug.
LOL
Alex Burr
Memphis, TN0 -
I thought the plug is at the bottom when the star is in the "window."0
That's what the book says. I'll just ignore the other plug (beyond making sure its tight).0
- 115 Hudson 1916 - 1929
