fluid used in convertible top system
hudsontech
hudsontech Senior Contributor
Fellow posted on the chat page (with an email addy at that) as follows:
wards wardsautoparts@aol.com 08/13/10 13:18:41
Good day: I have a customer here to restore a Hornet from 1954. He wants us to repair the hoses to the convertable top. Question is what type of fluid did they use for this hydraulic system? (Brake fluid or some type of ATF / Hyd fluid ?
Alex Burr
Memphis, TN
    Alex Burr
    Memphis, TN
    Back then we used brake fluid and never had a problem. Walt.
  • hudsontech
    Thanks Walt - this is a little embarassing for me as this is something I should know and can't remember. The old CRS syndrome. I thought brake fluid would work.
    Alex Burr
    Memphis, TN
  • Park_W
    Park_W Senior Contributor
    One caution ... never, never put SILICON brake fluid in the convertible top system. I has no lubricating qualities and will ruin the pump. There's a big note on this from Hydro-Lectric. They recommend power steering fluid if you're starting with a fresh, dry system or have thoroughly flushed it.
