1931 Essex Driveshift
Just unbolt it and it will fall out! There are 6 bolts at each end holding hte flanges on.0
Maybe you're having trouble like I had on my 30. The slip joint on the front yoke of the driveshaft was dry and corroded and when I removed the bolts the driveshaft flange just fell down on the nut on the transmission flange shaft. I had a time trying to pry the two apart before the driveshaft flange would clear the nut and fall away.0
- 115 Hudson 1916 - 1929
