Need lower body trim for 52 Hornet Coupe
Unknown
Looking for the three 5/8" painted trim pieces (per side) that run along the top of the rocker panels. Anyone have a set (6 pieces- both sides) ? This is for a coupe. Thanks, Niels
  • RL Chilton
    Get back to you on this, Niels. I think I might have an extra set.
  • Looking for a set of these 6 trim pieces as well. Does anyone have any in good shape that they want to sell. 52 2door hornet. Please let me know. Thank you
  • RL Chilton
    Ray-
    Have you gotten ahold of Russ Maas? He had these re-popped in stainless for 2 & 4 DRs, I believe. They can be roughed and painted like originals or polished for more bling. Even if he is out, I'm sure if he gets more orders, he'll order another batch.
  • RL Chilton wrote:
    Ray-
    No I didnt know they were being made. Do you have his contact info?
    Thanks Ray
  • RL Chilton
  • RL Chilton wrote:
    As always thanks Russ,
    Need additional help, see message and pictures from Allen.
    "Hi Ray,
    When you get a chance can you post to the form and see if anyone has a picture of the pictured brackets mounted to the
    rear frame rails please. I cant seem to figure out how they screw to the frame rail behind the quarter panel Just above the
    rear rocker by the bumper. They don’t seem to fit under the quarter. Like they are wider than the opening."
    Thanks Allen
  • Ray I believe the brackets being shown are part of the fender extentions which go on the bottom back of each fender. See the attached pictures and note the brackets at the attach points.
    Good Luck
    Ken
    Good Luck
    Ken
    Thanks Ken,
    I'll forward onto Allen, looks like fender skirt latch secure piece, which I don't remember seeing in boxes of parts?
    Ray
