Question- painting underside of hood
Unknown
In 1954, was the underside of the hood painted the same as the exterior or was it a flat black? The car I am restoring had been repainted and the underside of the hood was the same color as the exterior.
Thanks in advance for the feedback.
  • Underside of hood should be same as exterior of hood to be authentic, exception might be if hood was replaced when car was fairly new, replacement crash parts came in a black prime coat and most body shops did not take the time to repaint the underside.
  • Underside of hood should be body color, plus some had padding on the underside some did not. It is up to you which you choose.
    Bob
  • Thanks Steve and Bob.
