problem with mouldings
[Deleted User]
Hello
have you a solution or should it change mouldings?
they are arcs after dismounting
thanks
  • pierre from france wrote:
    Hello
    thanks
    I can straighten those
  • I am very slowly with little Platinum alle . J have not oil
    Monroe , What can do you with it? are you working as the chrome?
    thanks
    thanks
    Chrome no. Make trim straight and repair it well and polish.
    "J have not oil" Understanding?
  • Walt-LA
    Walt-LA Senior Contributor
    De ma part, je n'ai jamais vue une telle chose. Qu'est que c'est vous avez utilise pour enlever la moulage? Un <platinum alle> Ca veut dire? Il ne faut qu'enlever la cote inferieure de la moulage avec une spatule, ou une chose semblable, que vous passez petit a petit toute la longue de la moulage. D'apres, vous pouvez la detacher facillement a main. Il me semble que vous avez essayer d'enlever la moulage avec l'util traversant completement la largeur de la moulage et cela soit responsable pour la courbure.
    Walt-Louisiane
  • oh sorry : platinum alle is spatula and oil is wd 40
    walt vous avez raison, j ai souleve doucement , mais sur toute la largeur de la baguette ; voila l erreur que j ai commise :cool:
  • Interesting thread........have no idea what it's about.......but it is interesting.............:]
  • Walt-LA
    RP,
    The problem was the spatula used to lift the molding was all the way across the retainer strip - so that it freed both sides at once. That is what caused the molding to bend. Kinda like opening an old fashioned sardine can with the key... it rolled it up. Walt-LA
  • Walter, I believe the French word for this moulding is' fubared'. We here in America have a similar word.
  • Walt-LA wrote:
    RP,
    I've seen that stuff before when straightening Hudson trim, I can fix that rolled up piece, the 50-51 profile is not any easy find, it is easier to unroll though
  • Hudzilla
    is the word in French" baguette chromee"
    pierre
  • 54SuperWasp
    54SuperWasp Expert Adviser
    HI Hudzilla, in Canada, the french word for "mouldings" would be "moulures".
    You could go to any body-shop and they will understand you. How about it in France, Pierre? Would you guys understand the word "moulure" talking about cars? As for the word "fubared" I would be curious were you found that. Never heard it in french or english and tried to find it in the dictionnary too but with no chance at all. I love new words! It's fun to put it in a conversation and look at the reaction:confused:.
  • 54SuperWasp
    Oui Pierre, on pourrait dire aussi " moulures chromées" pour " chromed mouldings". Even if it's stainless they will often talk about chrome.
  • Ol racer
    Ol racer Senior Contributor
    Pierre,
    The Pictures of your Hudson Coupe Project reveal how deeply that you are doing your restoration..... Keep up the nice work!
  • 7XPacemaker
    7XPacemaker Senior Contributor
    If this is the rear quarter mouldings, I think that I have a pair if you are interested.
  • bent metal
    bent metal Senior Contributor
    Walt-LA wrote:
    RP,
    That's what I was thinking too.
    You can also get the same result if you pry up one end of the moulding, and tie a rope around it. Tie the other end of the rope to a sturdy work bench in your garage. Then get in the car and accelerate out of the garage as quickly as possible. This will release the moulding from the car and give it that round shape your looking for. By the way, if that fits your fender I think I would work on getting it a little more straight before working on the moulding.;):D
  • 54SuperWasp
    HI Hudzilla, as I told you, I love new words and the reaction of other people hearing it. Finally got the "real meaning" of your new word. No wonder it's not in any dictionary. I'm sure I will use it someday. Thanks!:D
  • hello
    super wasp, in French we take the word "moulding" especially for everything which is wood, antique furniture
    je te dits en francais au cas ou mon anglais est mal exprime , si tu veut bien leur expliquer . Moulure en francais designe la forme de la baguette, le relief , mais il est surtout employer pour les objets en bois , tels que les meubles , anciens surtout
    voili voilou :)
    Pierre
