1920 Super Six
The bonnet(hood) sides on my Six has four holes above and four holes below the lourves. Should anything fit here or should they be blankeds off. Also the moulding between the screen and scuttle is missing, there are threaded holes in the scuttle - was the original rubber ??
Many thanks
Many thanks
The holes are for snaps that are for a cover that one could put on to cover the louvers up in the winter time. I cant help you on the screen and scuttle as I don't know what a scuttle is.0
Hi, Thanks, In the UK the scuttle is the curved area of the body below the widescreen, it has a recess to take the rubber (?)seal between it and the widcsreen frame.0
You need to join up to hudsonsupersix16-29@yahoogroups.com They deal with only huson cars of your age. This site is more geared for all them new fangled hudsons.
Good luck0 -
Scuttle=cowl, on this side of the pond!0
