Hudson Jet Carbs on eBay
Sarah Young
There's 10 Hudson Jet Carburetors listed on eBay right now, holy smokes!
Click here to check out the listings!
That's quite an assortment of carburetors. However, I found the running problem on my Jet was due to an intake manifold air leak past the gasket, not my carburetor. I went to change the gasket and discovered the piece that connects the intake and exhaust manifolds is broken, so now I need to locate either that connector piece, an intake manifold or a complete manifold set.
Bruce Kerslake0 -
Hey Bruce ,I havve a couple Jet parts cars here. Bolth have the
single carb unit. Have not removed them so not 100% sure they
are not broken. Let me know if you are interested I could go
out with a mirror and get a good idea,
Roger0 -
Roger0 -
Yes, I'm definitely interested. Let me know, if you have a serviceable one and where you are located. I'm in Washington state.
Thanks0 -
Bruce I'm about 45 miles from St.Louis. I'll Look at what I have tommorow.
Roger0
- 110 Hudson 1916 - 1929
- 176 The Flathead Forum
