Source for bolts wanted
I'm looking for a source for 7/16 x 2 1/4 coach bolts ( carriage bolts?). They are dome headed with a square section at the top of the shank. I prefer the thread to be machined on rather than rolled but cost may determine what I get. The source needs to be prepared to sent these to New Zealand unlike McMaster Carr. I'm seeking 16 of these.
Thanks guys.
Thanks guys.
That's a common hardware store item here. I would think any big
home supply place here would send you some. I know "Home Depot" has a
on line store as does "Lowes". Use Google or Yahoo to search for them,
Roger0 -
Rolled threads are always superior to cut threads. Forming the threads work-hardens the material and creates favorable compressive residual stresses at the thread roots. The material's grain is reformed rather than interrupted by cutting. But, if the bolt is non-critical or lightly loaded with no fatigue loads than machine cut threads are fine and cheaper.
Thus concludes your short screw and fastener lesson for the day.0 -
I did spend a lot of money for this fancy education... I don't get many chances to show it off.0
Rolled threads may be stronger, but the problem is that the threaded section is fatter than the stem of the bolt. In this particular application, where the bolt holds the wood wheel to the hub, if you use a rolled thread bolt the stem is somewhat smaller than the hole. The original bolts were a tight fit in the hole through the wood.0
I understood that a rolled thread meant that the thread diameter was greater than the shank diameter thus being difficult to achieve a tight fit through the hole & that a machine cut did not have this characteristic.0
Ah, I see why you need machine cut threads.
The rod stock that makes a formed bolt is slightly smaller since material will be forced out of the roots and into the crests of the thread. I was just addressing the strength aspect.0 -
Hi David, are these for your wheels?
Mike0 -
Hi Mike
Not for the Essex but for a friend's early Dodge wheels.
Dave0 -
If they are the same as a Essex I have a whole lot that have been chromed
Mike0
- 105 Hudson 1916 - 1929
- 173 The Flathead Forum
- 599 Vehicles
