7c tie rod end part question
hoggyrubber
hoggyrubber Expert Adviser
i have looked up the tie rod ends in my new master list parts book and it lists 300348 and 300349. if i need both inners and both outers are both left ones and both right the same? do i buy 2 of each part #? thanks, hoggyrubber
  • bob ward
    bob ward Senior Contributor
    The inner and outer tie rod ends are the same apart from the LH & RH threads, you need a LH & RH pair on each tie rod. So yes, if you are replacing them all you need two of each.
  • Thanks Bob so that means if a ford tie-rod fit I can use it right ???
    I have another question if you don't mind.
    Where would I find brake shoes for my 31 Essex?
    Thanks George
  • bob ward
    98truck wrote:
    ..... so that means if a ford tie-rod fit I can use it right ??? ...
    Yes, some Fords of that era used the same tie rod end.
    Can't help with brake shoe info, but I would be tempted to go to a brake place and have them bond soft linings on your shoes, and they can skim the drums while they are at it.
  • hoggyrubber
    thank you for the info! i am ordering 2 each.
