7c tie rod end part question
hoggyrubber
i have looked up the tie rod ends in my new master list parts book and it lists 300348 and 300349. if i need both inners and both outers are both left ones and both right the same? do i buy 2 of each part #? thanks, hoggyrubber
The inner and outer tie rod ends are the same apart from the LH & RH threads, you need a LH & RH pair on each tie rod. So yes, if you are replacing them all you need two of each.0
Thanks Bob so that means if a ford tie-rod fit I can use it right ???
I have another question if you don't mind.
Where would I find brake shoes for my 31 Essex?
Thanks George0 -
98truck wrote:..... so that means if a ford tie-rod fit I can use it right ??? ...
Yes, some Fords of that era used the same tie rod end.
Can't help with brake shoe info, but I would be tempted to go to a brake place and have them bond soft linings on your shoes, and they can skim the drums while they are at it.0 -
thank you for the info! i am ordering 2 each.0
- 115 Hudson 1916 - 1929
