Wanted: Clifford Hudson 4 barrel aluminum intake
If you cant find one take a '49 aluminum intake then cut and/or mill off the 2bbl carb base flat then countsink to bolt a 4bbl adapter plate available swap meets on top with a gasket or mig the adapter to intake. I have adapted a couple of them and they work great with small Holley 4bbl.0 -
Thanks for the tip! David0
- 97 Essex Super 6
