51" Hollywood Rear Glass { Three Peice )
HornetSpecial
HornetSpecial Expert Adviser
Does anyone know if they remanufacture this glass? Or does anyone have any good used??
Paul
  • ski4life65
    ski4life65 Expert Adviser
    I am not aware of re-pops on these. I have heard a 54 Hollywood 1-piece will fit also, but have not confirmed this.
    Don
  • HornetSpecial
    Thanks Don. I would hate to have to use one piece in it. I am going to replace rubber, and would like to have in case i break one. I guess i better be careful.
    Thanks, Paul
  • VicTor Z
    VicTor Z Senior Contributor
    Copied from the H E T Web Site, Classified. :huh:
    NOS: Hollywood clear rear windows (center and left hand section); used rubber window molding; one inner and outer chrome/s/s molding. $450 or B.O. for all, or will piece out. Nine-inch clutch disc-$140, Center drive shaft support carrier cushion - $10 each. Clutch release assembly 1936—1954 - $125. King Pin Set: 1942-1956 - $105.
    USED: 1946/47 6-cylinder starter motor, MZ4092, $45.00; light and starter switches with good plastic buttons, $40 - each. Radiators $45.00; transmission $50. Step Down 1956 generator: $40 (also fits Nash, Packard, Studebaker, Willys, and Chrysler); oil pump, $20. Norm Wolff, 284 Oak Point Landing Drive, Mt. Pleasant, SC 29464, Phone - 843 216 6433, junowolff@bellsouth.net
  • HornetSpecial
    Thanks for info Victor
    Paul
  • ski4life65
    I was going to attempt to install mine soon. At that rate, I can't afford to break one.
  • drdoug
    drdoug Senior Contributor
    I have these if you break one-all 3 pieces-150.00 +shpg.. The biggest trick is to make sure the rubber is nice and pliable,mark the center of the glass and the body. If your car is painted,use masking tape on the body. The 2 bars in between the outsides are the key to it coming together. Did you take notes when you removed it?,ot just got it out somehow?. Good luck
  • HornetSpecial
    Whats your phone number Clutch guy?? Maybe we can do some business.
    Paul
  • drdoug
    317-398-4163. Leave a message and I'll call back. I'm going outside to load a car right now. I do have all 3 pieces. Thanks Drd
  • I will take them if he don't, does anyone else have any of these for sale also? mine are broke, thanks!!!! pm me back or email at: caribbean53@yahoo.com thanks
