Hudson Modern Part Number?
Ol racer
Ol racer Senior Contributor
edited December 2010 in HUDSON
A friend in Ga. is looking for crossover Part Numbers for Stepdown center driveshaft Carrier Bearing, the 2 Rubber Grommets, and a rear Wheel Bearing Seal.
I looked into a couple Links but could'nt find Numbers for him. If someone could help would be greatly appreciated.
Thanks,
Ol racer
  • GrimGreaser
    I have McMaster #s for the rubber dampers. I'll post those soon as I get a chance.
  • Clutchguy
    Clutchguy Senior Contributor
    Need more info on the year. When Hudson went to the Dana axle,the bearing# os 25877 and a 25821 race,both availible at Napa . The center support bearing-depends on the year.-88107 comes to mind,and the outer seal number was a CR-550154 or a n-1012.Driveshaft cushions-K-gap
  • Ol racer
    Clutch Guy & Grim Greaser,
    Thanks for the quick help. Not sure of the Stepdown Year, but I will forward these to him.
    Thanks Again... The people on this Forum are really helpful to keep Hudsons rolling....
  • GrimGreaser
    Rubber center bearing supports:
    McMaster-Carr:
    9376K46 (Same as 9376K127) - Natural Rubber Vibration Damping Sandwich Mnt Cylindrical, Male/Male, 5/16"-18, 1-1/4" H, 1-1/4" W - $1.89 ea.
  • mars55
    mars55 Senior Contributor
    Here are the part numbers for the bearings.
    '48-'52 All Exc Pacemaker and Wasp use #88506
    '50-'52 Pacemaker and Wasp use #88107
    '53-'54 All Exc Jet use #88107
    I am not totally sure about the above infomation. So here are the dimensions of the bearings. You can measure yours and pick the right one.
    #88506
    ID 1.1811 inchs
    OD 2.4409
    Width 0.9449 inchs
    #88107
    ID 1.3780 inchs
    OD 2.8346
    Width 0.9843 inchs
  • bob ward
    bob ward Senior Contributor
    Both of the centre bearings are standard metric sizes available at any bearing supplier. #88506 is 30id x 62od x 24mm, #88107 is 35id x 72od x 25mm.
    The rear axle oil seal is an off the shelf inch size item at a bearing supplier, 1 3/4"id x 2 7/16"od or 1.75" x 2.437". If you are removing an original Chicago Rawhide leather seal you will notice that the new neoprene item is a little narrower but it will fit and work OK.
  • Ol racer
    Thanks Bob Ward & Mars55 for the additional helpful Information. I will foward onto the Person requesting in Georgia....
    Really appreciated all the help....
    Ol racer
