Hudson Modern Part Number?
A friend in Ga. is looking for crossover Part Numbers for Stepdown center driveshaft Carrier Bearing, the 2 Rubber Grommets, and a rear Wheel Bearing Seal.
I looked into a couple Links but could'nt find Numbers for him. If someone could help would be greatly appreciated.
Thanks,
Ol racer
Thanks,
Ol racer
I have McMaster #s for the rubber dampers. I'll post those soon as I get a chance.0
Need more info on the year. When Hudson went to the Dana axle,the bearing# os 25877 and a 25821 race,both availible at Napa . The center support bearing-depends on the year.-88107 comes to mind,and the outer seal number was a CR-550154 or a n-1012.Driveshaft cushions-K-gap0
Clutch Guy & Grim Greaser,
Thanks for the quick help. Not sure of the Stepdown Year, but I will forward these to him.
Thanks Again... The people on this Forum are really helpful to keep Hudsons rolling....0 -
Rubber center bearing supports:
McMaster-Carr:
9376K46 (Same as 9376K127) - Natural Rubber Vibration Damping Sandwich Mnt Cylindrical, Male/Male, 5/16"-18, 1-1/4" H, 1-1/4" W - $1.89 ea.0 -
Here are the part numbers for the bearings.
'48-'52 All Exc Pacemaker and Wasp use #88506
'50-'52 Pacemaker and Wasp use #88107
'53-'54 All Exc Jet use #88107
I am not totally sure about the above infomation. So here are the dimensions of the bearings. You can measure yours and pick the right one.
#88506
ID 1.1811 inchs
OD 2.4409
Width 0.9449 inchs
#88107
ID 1.3780 inchs
OD 2.8346
Width 0.9843 inchs0 -
Both of the centre bearings are standard metric sizes available at any bearing supplier. #88506 is 30id x 62od x 24mm, #88107 is 35id x 72od x 25mm.
The rear axle oil seal is an off the shelf inch size item at a bearing supplier, 1 3/4"id x 2 7/16"od or 1.75" x 2.437". If you are removing an original Chicago Rawhide leather seal you will notice that the new neoprene item is a little narrower but it will fit and work OK.0 -
Thanks Bob Ward & Mars55 for the additional helpful Information. I will foward onto the Person requesting in Georgia....
Really appreciated all the help....
Ol racer0
