What year??
ESSX28-1
ESSX28-1 Senior Contributor
Found this available in an old car wreckers I visited a couple of days ago. Has HUDSON stamped on cap. Apols for the phone camera photo quality.
  • PAULARGETYPE
    PAULARGETYPE Senior Contributor
    IT LOOKS LIKE THE THE HUB CAPS ON MY 34 HUDSON SEDAN I'M GUESSING A SIDE MOUNT COVER OR A REAR TIRE COVER THIS IS NOT MY CAR BUT HAS THAT STYLE OF COVER I'D LIKE TO HAVE IT I HAVE JUST ABOUT EVERY THING TO MAKE A SIDE MOUNT ON MY CAR
  • ESSX28-1
    Paul' I'm sure they'd be happy to sell it to you, but do you realize it's here in New Zealand! Come down for a visit & pick it up!!
  • Browniepetersen
    edited January 2011
    I am not too sure that the tire cover matches the cap? I am confused by the oblong opening on the cover. Also, most of the full covers such as this that fit into a wheel well is cut on the fender side and not truly round. My guess is that it is for a rear mound and I think the cover is Ford between 34-36. The ones I have seen also have a "cap that holds the cover on the tire and goes across the tread of the tire? This is just a WAG.....
    I have a cover that is round that I plan to put on my Martz Roadster but it ends just beyond the rim of the tire. You see the rim and Hubcap in the cap opening...
  • It is the same as the REAR tire cover on my 35 Hudson coupe model HT
  • Forgot to say, it should also have a back half to be complete.
  • IT LOOKS LIKE THE THE HUB CAPS ON MY 34 HUDSON SEDAN I'M GUESSING A SIDE MOUNT COVER OR A REAR TIRE COVER THIS IS NOT MY CAR BUT HAS THAT STYLE OF COVER I'D LIKE TO HAVE IT I HAVE JUST ABOUT EVERY THING TO MAKE A SIDE MOUNT ON MY CAR
    I see you have 1936 Hudson wheels on your 34. Did you use just the center sections or the complete wheel? Walt.
