262 head torque spec and sequence
Majumbo
Majumbo Expert Adviser
What's the head torque an sequence of a 53 262 engine? Please help I just want to tighten them just incase they have loosened.
  • Uncle Josh
    Uncle Josh Senior Contributor
    edited January 2011
    7/16-14 Head cap screw specs from the Hudson Shop Service manual are 60-65
    Sequence is from the center outward evenly from side to side and end to end.
    You should buy one from the club store.
  • If you have Walt's tech tip books, volume one, (1) go to page 17 and page 46 and you will have the info you need. Walt.
  • schillaz
    schillaz Expert Adviser
    edited January 2011
    here check this out.
  • schillaz
    edited January 2011
    hope this helps
  • schillaz
    edited January 2011
    Hope this helps.
  • schillaz wrote:
    Hope this helps.
    The way Hudson designed to torque heads had a lot of blown headgaskets or leakage on the left side between cylinders 3 and 4. Walt.
  • Majumbo
    thanks guys! so wait... are you saying i shouldnt follow this sequence? haha
  • My way is the way we did it on our Hornet racing engines and never blew a headgasket. Using the Hudson way guys were having headgasket problems. That is all I will say. Walt.
