Window Crank Knobs
Hudson308 wrote:I measured again and got roughly the same results Chris, (minus my 1" addition blunder) within .005". As an added note, the dish features of style like your first CAD example measure as follows. The flattest portion at the bottom of the dish measures roughly .335" diameter, then tapers up to about .650" where the external radius meets the dish. That external radius looks like about 3/32" to my uncalibrated eyes.
OK, here are the two ivory knobs based (hopefully) on your dimensions. Am I getting close? Like I said earlier, the changes are easy - it's figuring out what to change that's hard.
John, How much shrinkage do you think? I'm guessing it would be small enough to ignore. I definitely don't think it would be enough to match the ivory knobs:
I'm guessing that the Pacemaker knobs were just smaller to go with the smaller car. Based on the pictures that I've seen, the handles aren't the same so why should the knobs be?0 -
cpr333,
I think that it's entirely possible for the Pacemaker knobs to have shrunk and deteriorated to that extent. The knob just feels too small and I cant imagine that Hudson would have gone to all that trouble to make or purchase smaller knobs for it's less expensive model. The material that was used for the Pacemaker knobs seems to have a unique property, different than the plastic that was used for the escutcheons and other dash knobs. My window crank knobs show signs of a kind of resin that has run out of them and hardened in the deterioration process, which I believe would have caused this unique material to shrink. I'm not disagreeing that Hudson may have used a smaller knob, I'm just pointing out my observations. Whatever size you make them will be far superior to what we have now.
John Forkner0 -
I find it hard to believe that Hudson would have specified a smaller size for the knobs used in the Pacemaker - I'd rather think the material was a kind of experiment to determine how it would hold up over time. Hudson would not have been alone in allowing there customers to "test drive" a car with a NEW material in a regularly used part.0
I could see some shrinkage, but this is something like 20%. Do you think a part could shrink that much and still keep its shape? Seems hard to believe.
As to Hudson not making a special knob, I think we all agree that they were a different color and material so whay not a different size or shape? The handles that I have are different than the ones pictured with the ivory knobs. Is that just a year to year difference or a model to model thing? I'm going to go home and look in the master parts catalog to see if they differentiate between handles or even knobs from model to model. If they made a different handle for the Pacemaker, why not the knobs too?
I would like to get a definitive answer but the truth is that we will probably never know. When we all come to an agreement and I get these things made, we'll just tell anyone that asks that they are correct. If we can't figure it out now, who will have enough infomation to argue?
After getting the size and shape right, the next question is going to be material hardness and gloss. Should they be hard and glossy or softer and more of a matte finish or some combination of the two? Maybe it was an experiement with softer material that led to the deteriorization.0 -
I guess I'm basing my opinion on the size by the fact that the dash knobs and heater control knob on the Westhermaster under the dash and the handle for the cowl vent are all the same size as on the senior cars. I'm sure the knobs would have been of a hard material - softer knobs and buttons had not come into play in the automotive business at that time.
These knobs have been a problem for years. If you take a look at ten 1950 Pacemakers at any of our Hudson gatherings, I'll wager that 9 of them will have the window and door handles replaced - either by the Super Series or Commodore/Hornet Series handles.0 -
cpr3333 wrote:I could see some shrinkage, but this is something like 20%. Do you think a part could shrink that much and still keep its shape? Seems hard to believe.
cpr-
I think you pretty much answered most of your own questions and I agree with you. There could have been vendor changes, which probably (and usually) warranted a new part # and the exact specifications of the knobs could have changed mid-model, mid-year without Hudson blinking an eye (it is a small thing, after all).
As far as shrinkage goes, look at steering wheels of the period. If left out to the elements, the shrinkage on the poured portion of the steering wheels will go from small crack to several inches. This "blank" section of the steering wheel did not crack and fall off, but actually shrunk away. You could easily lose 35-40% of the rim of the wheel due to shrinkage alone. This early-day "plastic" was actually poured resin, which was an improvement over the bake-lite material which can still be found in later step-downs on a few choice parts.
The major benefit was that the color was consistent all the way through, was manufactured quickly and eliminated the need for painting.
As far as an original "look" goes, that would be hard to say, but these knobs, when in good shape, and after years of being handled, are very shiny and smooth, due to being handled for extended periods of time. I'm sure that when new, the look was more of a matte finish.0 -
53jetman wrote:I guess I'm basing my opinion on the size by the fact that the dash knobs and heater control knob on the Westhermaster under the dash and the handle for the cowl vent are all the same size as on the senior cars.
Good point on the sizes being the same for all of the other knobs, handles, etc.
One more piece of data to consider: According to the master parts catalog, the handles were specific to the 1950 Pacemaker and Pacemaker Deluxe (except the convertible to be absolutely accurate). They were not used on any other model or in any other year. The circular section at the end of the handle measures 7/16" at the bottom and 3/8" at the top where the knob is attached. In the pictures posted by Hudson308, the same area seems to be bigger in the picture with the ruler. (Hudson308 - Could we get you to do yet another measurement?)
If the handles are smaller in that area, would that imply that the knobs were smaller as well?53jetman wrote:I'm sure the knobs would have been of a hard material - softer knobs and buttons had not come into play in the automotive business at that time.
I tend to agree but what was different about this material that made it deteriorate so badly? Maybe it was a first attempt at a softer material that didn't work out. Pure speculation, but who knows?53jetman wrote:These knobs have been a problem for years. If you take a look at ten 1950 Pacemakers at any of our Hudson gatherings, I'll wager that 9 of them will have the window and door handles replaced - either by the Super Series or Commodore/Hornet Series handles.
That's why I'm asking all of these questions. If I make some, I'd like them to be as correct as possible, not just another incorrect variation.RL Chilton wrote:
cpr-
Good point on the steering wheel. Mine has done exactly what you described.
As to the finish on the parts, I think I'll just try to match the escutcheons since that is what they are closest to.
While I'm on escutcheons, I modeled up one of those too just to see how it would look:
That's some awesome work there, CPR. I'm sure there's a small market for these, but you would have no problem selling extra stock. Can't wait to see the finished product.0
Those escutcheons look very nice and i could use eight of them in the 53 sper wasp color [BLUE] should you decide to reproduce them. keep me in mind
steve0 -
CPR
I would expect that the crank knobs were as shiny as the other interior plastic parts.
Again, I want to express my desire to get some of theose knobs from you if you decide to go through with production. Then the interior will look great except for the creosote staining on some of the door panel areas.
Geoff Blake0 -
RL Chilton wrote:That's some awesome work there, CPR. I'm sure there's a small market for these, but you would have no problem selling extra stock. Can't wait to see the finished product.
Thanks. Believe it or not, that took less than half an hour. It's amazing what you can do with a $20,0000 piece of CAD software and 15 years of experience using it.bartibog1 wrote:Those escutcheons look very nice and i could use eight of them in the 53 sper wasp color [BLUE] should you decide to reproduce them. keep me in mind
steve
If the knobs work out the way I hope they do, the escutcheons will be next. I'll let everyone know when I get to that point. I'll probably have to get a sample from you for the color but that's a while in the future.middletom wrote:CPR
Geoff Blake
I'll let everyone know before I do this to figure out how many to make. We still need to come to a consensus on the size.
I had a few made up this weekend as a test and I wasn't really happy with the dimple. I need to get with the guy who made them to see what can be done to improve the shape. After that, I need to decide on material and then paint and finish.0 -
If you are casting these, keep in mind that an additional step could be instituted in the manufacturing phase for the "correct" dimple, which, would be to chuck the knob up in the lathe and face the knob with a ground cutter to the desired profile.
Might even be simpler than that, with the correct size drill bit (again on the lathe), and followed by some simple shaping with sandpaper and polisher.
Just thinking outside the knob, here . . .0 -
Chris,
I think you need to decide yourself what makes you happy. I don't think that anyone will complain about what you come up with, it will be far better than what most people have on their car.
John Forkner0 -
onerare39 wrote:Chris,
John Forkner
Agreed!! Don't sweat the small stuff, Chris.0 -
Here is a new picture based on the latest dimensions:
The one on the right is from the earlier dimensions, the one in the middle is from the dimensions in the last post and the one on the left is halfway between the two.
Any preferences or other suggestions?0 -
I like the one in the middle.0
I would vote for door number two... the middle one.0
CPR,
I also think the middle one appears to be just right.
Geoff Blake0
