262 Twin H linkage
Roger Harmon
All,
Can anyone provide photos or illustrations of the 262 Twin H linkage? I need to construct a set. Thanks.
R/ Roger.
R/ Roger.
These might help from my car:
Is your 262 in a short or long wheel base car? If long wheel base, than it is the same as a Hornet. Short wheel base is different.0
The pictures are on a long wheel base. The linkage on a short wheel base are totally different. I have a 52 Pacemaker with twin H but its buried in a garage. If you have a 262 manifold the spacing of the bolts holding the carb. on is different also. I have just bought a didgital camera but, dont know how to sent pictures yet on computor. As soon as I can figure that out and dig the car out I will sent them.0
Mine's a short wheel base. I heard they were different. I look forward to the pictures. Thanks to all.
R/ Roger.0 -
Roger, Get in touch with Hudzilla, He may have a set.
HUDZILLA, aka: Lance Walker 1-704-792-9110
Bob Hickson0 -
for good factory pictures of the 262 linkage used in the short wheelbase cars check out the Hudson Factory Hydra-Matic Supplement manual from 1953. They show towards the back the 232 1bbl, 262 2bbl and the 262 Twin-H linkage layout and adjustments for the Hydra-Matics. Manual transmission versions would not have the extra arm on the bellcrank at the base of the block next to the oil pressure relief valve port used to set Hydra-Matic throttle valve pressure.
the attack pictures shows the bellcrank and its mounting location used on all short wheelbase Hudsons.0
- 115 Hudson 1916 - 1929
