Heat Shields / Gas drip shield
Vintage Coach... check with Jason0
Jason only has the WA-1 heat shields not the 2 barrel kind. Walt.0
John didn't specify which carb or Hudson year he was looking for (tsk-tsk!, John!). According to my Hudson Repro Parts page http://www.detailedconcepts.net/Repro_Table.pdf , Vintage Coach has the 1937-47 2 bbl. carb heat shields. They also carry them for the Twin-H setups (in pairs).
Please let me know if they no longer carry one of these, so I can remove them from the list!
(Thanks, Lee, for discovering the flaw in my link! Just fixed it!)0 -
Hi Jon B,
I got a message that said "Sorry, the page you were looking for could not be found" when I clicked on your Hudson Repro Parts page link. What went wrong?
Lee O'Dell0 -
Lee, it looks like when you click on Jon's link, it is adding a "," to the end. Backspace and remove the comma and it loads fine.0
I checked with Jason at Vintage Coach and he does not have any 2 barrel heat shields available.0
They are easy enough to make with a minimum of tools. I made up a bunch of them - unfortunately that was back in the 1970's (back in the dark ages!!) All I had to hand was a pair of tin snips - forget now how I cut the holes. I used lightweight galvanized tin. Worked fine. Maybe not as fancy as stainless steel, but..........
Alex Burr
Memphis, TN0 -
Surely some one over there can help you with one of these, if not, I think I have a couple of second hand ones in the garage.0
Would appreciate someone posting a picture of a heat shield.0
Where fore art thou, Bent Metal?0
Ask Al Saffrahn.0
dave kastelic wrote:Would appreciate someone posting a picture of a heat shield.
Here are pics of the heat shields for a 202 Twin H
BTW The shields are on the intake upside down. If there are only two ways to assemble something I will ALWAYS do it wrong the first time.
Kevin C.0
- 104 Hudson 1916 - 1929
- 173 The Flathead Forum
- 599 Vehicles
