Pilot bearing #
Unknown
I need the currnet bearing # for the clutch pilot bearing for a 33T8. I think it is the same as all of the later Hudsons.
  • Just order one from Doug Wildrick. Walt.
  • bob ward
    bob ward Senior Contributor
    IF its the same as the later Hudsons, I'm talking stepdowns here, the pilot bearing is a bog standard, not very exotic at all, 30mm x 10mm metric bearing, available from any bearing store for 2 or 3 dollars.
  • mars55
    mars55 Senior Contributor
    The stepdown clutch pilot bearing is a National 200 or a NAPA 6200J.
  • Thank's for the info.
