Clamp - Tank Neck Protector 4.144 302308
[Deleted User]
edited February 2011 in HUDSON
I think I have the correct item in the subject line. This should be the triangle, 3-pc clamp that holds some type of Protoctor - Tank Neck 4.141 301258 in the trunk floor on my 1950 Pacemaker.
1) Am I correct in properly identifying the part?
2) What does the Protector - Tank Neck look like? Mines was not OEM, mostly a flat rubber sheet with some "roofing tar" like substance.
3) Would someone please be so kind and post full scale tracing of the three
pieces for the clamp? I have cleaned up the trunk floor and find the three nut & bolt holes. Two pieces of the clamp were still on the car "glued" by the
undercoating.
  • I made a tracing of some pieces I had - hope they show up . Also they used pins not bolts to hold them in place. Not that it would matter I suppose. They used about inch long pins with a small tinnerman or castle nut pushed on,
    Roger
  • THANK YOU! THANK YOU! THANK YOU!
    That is exactly what I needed. Now to the Army Base Craft Building for some metal work.
  • Glad to help, they were made of sheet simmilar to the rest of the body .
    Roger
