1949 Super Six Ebay - CA Car
rambos_ride
This looks like a really nice car...I wish mine had been this nice:(
I wonder what it will go for?
http://cgi.ebay.com/ebaymotors/Other-Makes-Hudson-Super-Six-HUDSON-1949-SUPER-6_W0QQitemZ4593007687QQcategoryZ6472QQrdZ1QQcmdZViewItem
Ah, I'll guess he's got a 7K reserve on it.0
I think alot can be told by how an e-bay ad is written. This guy sounds like a gentleman and I betcha the car is NICE. Niels0
I've got 8K, 4 yrs work and several worn out wire brushes in this one.
http://groups.msn.com/HudsonEssexTerraplaneBulletinBoard/unclejoshshudsons.msnw?action=ShowPhoto&PhotoID=26530 -
Wow. Nice looking car. I love the colors, too. Niels is right . . . the description is well written and the owner sounds like a good guy. My guess is this car should go for between 12,000 and 13,000, although being in California, my experience so far is that E-Bay cars from California generally have a higher reserve than the rest of the country.
Good find for someone . . . they should end up with a very nice car.
Russell0 -
Anybody know anything about the dry disk clutch the seller speaks of? Is this a good idea?0
mars55 wrote:Anybody know anything about the dry disk clutch the seller speaks of? Is this a good idea?
There is nothing wrong with a dry clutch in a Hudson - the 55/56 and Jets had them - as long as it is properly done. The main thing here, to make sure you have a trouble free installation, is to have a thicker flywheel turned up and fitted when the swap is being done.
If you have a look at a wet Hudson flywheel you will see that it is a fair bit thinner than a comparable dry clutch flywheel of the period. Heat and warping considerations mean a dry clutch needs a thicker flywheel. Hudson could get away with the thinner flywheel because a wet clutch runs way cooler than a dry clutch.
That's not to say a standard Hudson flywheel won't work at all with a dry clutch, for gentle driving it may be OK, but be prepared for serious clutch shudder if you do a lot of hill starts0
