CRANKSHAFT, 51-54 or 55-56?
I have a 1955 308 engine and I wanted to know if it had a 51-54 or 55-56 crankshaft. This information is for all with same question about there engine.
Thanks to Walt Mordenti I have the answer.
If there is a 1/2" spacer between the crankshaft and flywheel it is a 55-56 crankshaft.
Mine didn't have the flywheel mounted. So:
Measure from back of block, by the seal, to the flywheel side of the crank flange.
If it measures 1 1/2" it is 51-54 crankshaft.
If it measures 1" it is 55-56 crankshaft.
Now I know my 55 engine has the 51-54 crankshaft.
Thank you Walt, you get more Karma for this information.
Lee O'Dell
Lee O'Dell
This won't help you tell which crankshaft is which, but they also have different flywheel bolt patterns.0
bob ward wrote:This won't help you tell which crankshaft is which, but they also have different flywheel bolt patterns.
You are right Bob, it does't ID bare cranks. But it does help if the intent is to instal a 55-56 engine into a stepdown. Especially, since the 56 only had one crankshaft and the 55 came with both 51-54 and 56 type crank.
It would be helpful to be able to ID a bare crankshaft at a swap meet or anywhere else. That brings up some new questions.
What are the differences between bolt holes? Measurements.
Would the measurements I mentioned be close, if measuring from the crank flange to the rear seal surface of the crank? If not what would the measurements be.
Are there any other differences that may be measured?
Is there a part number on the cranks?
Will someone provide the information to ID a bare 308 chankshft?
Lee0 -
Its a while since I've looked at the ends of 308 cranks, but I think there are 2 different flywheel flange diameters as well. That would be one sure fire method of on the spot crankshaft ID, I'm sure someone on here will know what the differences are.
Another ID method would be to know the 2 dimensions from the flange to the rear bearing journal, there will be 1/2" difference between them.
I've always assumed (dangerous I know) that Hudson made the ends of the stepdown and hash cranks different to prevent the incorrect interchange of flywheels and flexplates.0 -
If it has 6 holes and bolts through them it's a 51 to 54. If it has threaded holes, it's a 55 or 56. Walt.0
walts garage-53 wrote:If it has 6 holes and bolts through them it's a 51 to 54. If it has threaded holes, it's a 55 or 56. Walt.
Can't get any simpler then that. Thanks Walt.
Lee0 -
So are the diameters the same?0 -
What's the difference, can't use the flywheel from one to the other. Walt.0
walts garage-53 wrote:What's the difference, can't use the flywheel from one to the other. Walt.
Wasn't my question.0 -
The flywheel flange on a 55/56 308 crank is 4.5" diameter. Can't help on the stepdown variety at the moment.0
51 to 54 crank flange measures 4.000 to 4.025. I have 2 and this is what each measures. Doesn't mater as the flywheel has a larger opening, up to 4.075 Walt.0
another simple identifier is the stepdown crank flange has one hole that is unequally spaced on the pitch circle and hash are equidistant.0
- 104 Hudson 1916 - 1929
- 173 The Flathead Forum
- 599 Vehicles
