Wanted 36 Terraplane running board edge trim
[Deleted User]
edited March 2011 in HUDSON
I am looking for a pair of running board edge trip for my 36 Terraplane. Any idea were I can locate them would be much appreciated.
  • barrysweet52
    barrysweet52 Expert Adviser
    I havent seen any on restored cars. They get damaged very easily. I have seen people use the rubber/plastic outside door moulding that is often used on modern cars. Regards, Barry
  • Ol racer
    Ol racer Senior Contributor
    Ive utilized a long shiny aluminum rocker panel moulding from an early 1980's model Olds Seden that fit nicely on my running board sides but of course it isnt original. I also have used the the 3m Tape on plastic chrome moulding that looks decent....
  • Just wonted to clarify what I am looking for. It is the steel piece that bolts to the outside edge of the running board that continues the half round bead from bottom of the front fenders to the rear fenders. Mine are rotten. If a good pair can't be found I will have to try and make them from sheet metal.
    Thank you
  • bent metal
    bent metal Senior Contributor
    Before too long I too will have to figure something out for that piece. I'm probably going to make them, how long are yours?
  • 4Hud
    4Hud Expert Adviser
    edited March 2011
    This bead is stamped integrally into the edge of the runningboard on our '36 Hudson. It is apparently different on the Terraplane. Any close ups and profile pics.
  • essexcoupe3131
    essexcoupe3131 Senior Contributor
    i had mine made in st/steel, they weren't (the cost) that bad at all
    cant remember what it was exactly, but I didn't pass a kitten lol
    mike
  • Clutchguy
    Clutchguy Senior Contributor
    edited March 2011
    I think you can possibly check with Dave Sollon. He might have a picture of what their supposed to look like. CG
  • dave s
    dave s Senior Contributor, Moderator
    I will post pictures of each side on Thursday PM.
  • dave s
    edited March 2011
    They are 49 1/2 " and different on ends. blue one is left side
  • Clutchguy
    Dave, thanks for posting the pics. It appears that there is 2 different types?. I can't really tell by the pics. Thanks again for posting.
  • dave s
    only difference is half rounded part is to end in front to line up with fender and it is rounded off a few inches before end of running board. This piece has bar 1/4" x 1 1/2" full length, that adds strength to running board and holds rubber mat in place.
    this is front
    this is rear
  • dave s
    go to this link to see Scott White's beautiful 1936 T pickup before and after
    http://www.whiteaeroltd.com/Terraplane.asp
  • essexcoupe3131
    very nice pick up as we call them down under
    very well detailed , to be proud of as Iam sure you are
    Mike
