AXEL BEARING NUMBER
PAULARGETYPE
HI ALL I'M LOOKING FOR THE NUMBER FOR A HUDSON AXEL BEARING FOR A 50 HUDSON I KNOW IT ENDS IN 77T BUT CAN NOT REMEMBER THE REST OF THE NUMBER THANKS IN ADVANCE
25877T good luck0
I've got some if you need them Paul.0
Paul, The T is very important.I have a very funny story about my brother 40 years ago when he replaced his rear bearings with 25877 istead of 25877T. Drove to Kansas City with his 50 pacemaker. Will tell you sometime. PS I hear they are hard to find?0
1951hornethardtop wrote:Paul, The T is very important.I have a very funny story about my brother 40 years ago when he replaced his rear bearings with 25877 istead of 25877T. Drove to Kansas City with his 50 pacemaker. Will tell you sometime. PS I hear they are hard to find?
The 'T' means tapered inner race, meanint the inside race diamater is tapered like the axle. According to the Hudson repair manual the proper procedure for installing the bearing is: Heat the bearing in oil to about 165 degrees, place on axle and using a peice of pipe that fits over the axle and contacts the inner race give it a whack with a hammer to set the bearing. When the bearing cools it will tighten on the axle. Pack bearing after it cools. Of course Hudson says use tool # whatever to set bearing, but like I said a piece of pipe works the same. That is how I did mine a few years back.
I believe the Hudsons with the Dana 44 rear end (52 and newer) used the standard 25877 bearing. Correct me if I'm wrong. Parts books mistakenly list the 25877 bearing for all years back to about 1936. I got the wrong bearings at first.
Jim Spencer0 -
Thanks , I know but my brother was just a kid and didnt know. I rember heating them but dont rember how. Good info to know in the future.0
Isn't this the bearing made of unobtanium?? Or at the very least rareatanium??
Alex Burr
Memphis, TN0 -
I DON'T NEED REMINDED OF ALL THE HULLABALOO I JUST NEEDED THE NUMBER I'M OLD AND THE MIND DOESN'T WORK AS FAST AS IT DID 5 OR 8 YEARS AGO SO THANKS FOR ALL THE HELP MY BROTHER DAVE SOLLON BEAT YOU ALL TO THE PUNCH HE HAD THE # IN MY EMAIL THE NEXT MORNING AGAIN THANKS I THINK I FOUND A FEW OF THEM WILL KEEP ALL POSTED HUDSONLY PAULARGETYPE0
- 115 Hudson 1916 - 1929
