Today's "what is this?" picture
ski4life65
ski4life65 Expert Adviser
edited April 2011 in HUDSON
I think this is an interior part, but where does it go? I am not even sure it goes on the Hollywood. It was in one of the many boxes of parts that came in the car, which was already disassembled when I got it.
thanks
Don
  • It goes under the aluminum cover for the treshold of the doors on step downs. there is also a black metal piece that goes with it.
    thanks
    Don
    Don as previously stated this piece is part of the door scuff panel and is installed under and outside of the piece labeled with the HUDSON name. Below both of these items should be a ribbed steel plate that supports these aluminum pieces. The steel plate is ribbed along it's lengh and fits inside and under both of the aluminum scuff plates.
    Hope this helps.
  • Lee ODell
    Lee ODell Senior Contributor
    Do the 1947 models require the same kind of parts under the scuff plates?
    Lee O'Dell
  • Browniepetersen
    edited April 2011
    Life is good... The older the car, the fewer the parts. My 36 does not have door plates. The carpet ends (I am excited that is has carpet) right where the wood floor ends and the running boards start... Well, I guess it does not show in this picture--oh well?
  • hudsontech
    hudsontech Senior Contributor
    The older the car the fewer the parts - I know that's right. 1920's parts books
    were around 50-60 pages, 1930's up to 100-110, 1950's upwards to 200 pages.
    We all get fatter with age I guessl. :)
    Alex Burr
    Memphis, TN
  • I DONT BELIEVE THAT PArt is FOR THE PLATES ON THE DOOR SILLS. I BELIEVE THEY ARE THE STRIPS THAT HOLDS THE PANEL BETWEEN THE DOOR AND COWL. THEY ATTACH RIGHT NEXT TO THE DOOR PANEL.
  • Uncle Josh
    Uncle Josh Senior Contributor
    That was my first impression. Like under the dash on the sides.
  • dougson
    dougson Senior Contributor
    edited April 2011
    Yes, it is the vertical piece at the front of the door that the windlace is stapled to (note staple marks) and it has a track to accept the kick panel. It's attached to the pillar (screw holes).
  • ski4life65
    Thanks for the help as usual :)
  • bent metal
    bent metal Senior Contributor
    edited April 2011
    Looked like a plasma cutter to me, maybe a MIG.;)
