King Seeley Gauges & Senders
Hi There
I have been Looking for information on the old Gauges for a 1934 Hudson LU, but am not having mutch luck. Do you know anyone that could help I am told that the wire is Ni-chrome wire 36 gauge but do not know what the technical details are for the wire. If I could get a book on the King Seele Gauges repair & maintenance with spesifications it would be gerat, It has to be wound on the BI-metal strip which has a sharp edge as per photos & the Insulation must be Heat Resistant. Apparently there are quite a lot of variations in heat with this type of wire.The Gauges are King Seele 6 volt and work by heating the Bi-metal strip Points open and close continually to give the readout at the gauge. Hpoe you can help.
Regards J B Leech {New Zealand}
Have you asked Geoff Clark in Wakefield, Nelson?0
Hi there yes Geoff Clark is a Member of the NZ.Het Club.Geoff did not have the technical information for the wire used in the Gauges. Thank's Regards John.0
johnbowman wrote:Hi There
Not sure if this is a good source for the wire you seek, but this site is for a compamy whose business is focused on the repair of King Seeley Guages.
Classic and exotic Services0 -
Do not think I could do the Bigboys any harm Regards John0
John,
I used a company that has been in the repair business for many years here in Ohio to do my 36 Terraplane gages. His name is John Wolf and I gave him a call and he said he would be glad to try and help you out. His phone number is 440-942-0083, and e-mail is jwolfco@gmail.com. Good luck.0 -
I have a complete speedo head with the gauges in it if you need it it is real low millage0
Hi there I do have a spare But the Gauges are not good I would be interested in
the one you have. Could you send me a photo & price0 -
John
email me and i'll send you photos of the dash my email is hethudson1957@aol.com drop the het from the email address it's just there for the spam bugs
HUDSONLY
PAUL0 -
here are the photos of the dash insert0
John, what would you want for your nofunctional gaugehead?
Email me at BJHickson@charter.net/// Remove the Backslashes0 -
Does anyone know what the ohm range is for these 1934 Hudson fuel sending units? Sounds like 73 to 10 ohms, is that correct?0
This is a bi-metal unit, not resistance. the rate of open/close duration depends on the tension applied to the bi-metal.0
On 6V a resistance sender with a range of 150Ω (empty) to 30Ω (full) is a viable substitute for an original sender. The ohm range is derived from the amperages for testing the operation of the fuel gauge that are quoted in the 34 to 39 Mechanical Procedure Manual, those are 40mA (empty) and 200mA (full).
Dakota Digital sell a universal sender with a 34/5 screw pattern and a 180Ω to 10Ω range which can be tweaked to work with the gauge. When testing and tweaking never apply 6V directly the gauge, it will quickly burn out.
https://www.dakotadigital.com/index.cfm/page/ptype=product/product_id=112/mode=prod/prd112.htm
- 175 The Flathead Forum
- 602 Vehicles
