Broken ring
Kdancy
Kdancy Senior Contributor
Looking for a replacement piston ring for the 37. When I pulled the 37 apart, #4 piston had a broken ring. The rebuilder must have installed it that way as it just dropped out when the piston came out. The pistons were .030 over. The ring is #3 from the top down.
Piston dia. is 3.005
Ring width is .187
Anyone have a single piston set I can purchase?
  • KERRY try Lester Harris--775-267-2559- I've had good luck with him , fine gentleman
  • If piston is .030 oversize-- would read 3.030. I may have some rings. Will Check.
    Randy
  • Kdancy
    Randy, thanks -- but Hastings rings just called me from my e-mail to them yesterday and after looking at my specs and photo's they had a ring to match and are sending it out today.
