valve seals?
starting to put the 37 Terraplane engine back together and have a question- part of the valves had what looks like to me, valve seals (a seal and small spring) and some didn't. I can't find mention of a valve seal in the parts book but assume they had some type of seal to keep oil down below the head ?? The seals are not in the master gasket set I have.
Back in the 40's, 50's, 60's and 70's these were sold to stop oil coming up through the intake valves. They worked on all valve in block engines. Sets were also sold for overhead valves. Walt.0
Throw them away.0
Geoff C., N.Z. wrote:Throw them away.
into file 13 they go!0 -
toss em is fine but do check stem clearance -you may need new guides0
I checked stem clearance and all is well!0
- 104 Hudson 1916 - 1929
- 173 The Flathead Forum
- 599 Vehicles
