1932 Firewall body tag wanted.
32huson
32huson Member
edited April 2011 in HUDSON
Wanted the identification tag from firewall/body of a 1932 essesx terraplane for my coupe. Tag with serial number between 350000 and 364125 needed.
  • 32huson
    32huson Member
    BTT I am still looking for an original 1932 Serial plate.
  • Geoff
    Geoff Senior Contributor
    I can supply you with a ESSEX MOTORS I.D. plate with your number stamped on it, if this will do the job for you.
  • essexcoupe3131
    essexcoupe3131 Senior Contributor
    good on you Geoff
  • 32huson
    32huson Member
    I do not know the number of the car I have.
  • Geoff
    I can send you a blank one and you can stamp your own number into it if you like.
    $55.
  • 32huson
    32huson Member
    Thanks. I will keep that option in mind. Can you send me a picture of the blank tag either in a private message or on here ?
  • btt
  • btt still in need of an original serial number plate
  • Bumping this old post to the top of the forum for those who might not have seen it before. I am still in need of the serial number tag for my coupe project.
  • I thought I saw these body tags in the K-Gap catalog.
  • Thanks 5433HET. I am looking for an original that allready has a serial number stamped perhaps from a donor or parts car would be great if I can find one.
    BTT I am still in need of an original correct year and serial number tag .
    BTT I am still hoping to find an original tag.
