terraplane spark plugs
GDay Skipster
I run B6S NGK in my '42 Hudson 212 cu in
Available from any Supercheap, Repco etc etc.0 -
Cheers,thanks for the info.This forum is a great resource for a beginner,very glad i joined0
Talking of Spark Plugs, does anyone have a source for 18mm LONG REACH plugs as originally used in the Essex engine. The regular reach ones I currently use work fine but I'd like to try the long reach type.
Thanks0 -
Are you sure J8's protruded too far? As I found the opposite as they are short reach plugs.
This was what I said on the report I posted here on my '36 Terraplane with high compression last year:
"Also researched a bit on plugs as all my cars seem to have the short-reach plugs such as Champion J8 or NGK B6S which end up with the plug recessed. The correct plug appears to be NGK B6HS which is 1/2" reach."
I did put the NGK B6HS plugs in and they are just perfect on my head (112 head), although I'm sure the standard '36 head is just the same in terms of spark plug depth as I had both heads on the bench to compare. The J8's being 3/8" reach result in a recessed sparkplug which is no good for efficient combustion, as well as leaving threads exposed in the head due too the too short plug.
So from my investigations, the 1/2" reach plugs are definitely the correct ones to use, and NGK make a very good plug.0 -
Bought 6 of the NGK plugs today from the spare parts bloke up the road,brand new,$1.50 each,will put them in tomorrow and see how they go.thanks again0
Interestingly the Mechanical Procedures Manual for the 1937 models lists the Champion H10 as the correct plug for the high compression head. This is a 1/2" reach plug. The Champion J8 is listed as the plug for the standard head for '36-'37.
The strange thing is that the 3/8" J8 is definitely too short for both the standard '36 Terraplane head and the '38 112 head from actual observation. I can't think of any logical reason for it being specified as it is by Hudson unless to help reduce the compression a little by its being shorter. It certainly doesn't make sense from an efficiency point of view, as it results in a recessed spark plug tip.
As far as valve head clearance is concerned there appeared to be plenty using the 1/2" reach plugs and that was with my head having being shaved as well. Certainly nothing has touched after a fair bit of enthusiastic driving and I don't think that would happen anyway as the measured clearances looked ample.
Well here in NZ we get ripped off, my NGK's cost $US4.50 each!! I bought 14 of the sods, one set for my H8 and one set for the Terraplane.0 -
About to buy new plugs for the 37 Terraplane PU.
What is the consensus now for the proper plug?0 -
Kdancy wrote:About to buy new plugs for the 37 Terraplane PU.
Irrespective of the name and code of the plug, a standard 1/2" reach plug of the correct heat range is what you want.
A Champion J8 is a 3/8" reach plug here in NZ (hard to think it would be any different in the US) and as I said it is too short to reach the end of the spark plug hole in the head.
The NGK B6HS plugs I put in work perfectly.
As a matter of interest why not take a plug out of your head, look down the spark plug hole and get a measurement on its depth? If you've been using the short plugs you should see that the last 1/8" of threads in the head are carboned up due to the short plugs not extending to the full depth of the hole.0 -
The standard head takes Champion J-8, set at 0.025". The aluminum power dome head take Champion H-10 set at 0.025. This is right from the Hudson 1937 manual. The eight cylinders only use the J-8 plugs. Walt.0
walts garage-53 wrote:The standard head takes Champion J-8, set at 0.025". The aluminum power dome head take Champion H-10 set at 0.025. This is right from the Hudson 1937 manual. The eight cylinders only use the J-8 plugs. Walt.
Walt, 3/8" or 1/2" reach? As I said, I have found by physically fitting that the 1/2" reach is correct for both a standard '36 Terraplane head and a later 112 head.0 -
Walt is right go by the book J-8 IS the correct plug there is only one J-8 plug dont second guess the Champion sparkplug book they know alot more about plugs than anyone on this forum.0
Don't fool around, if cast iron use the J-8 plugs. If you drive it on a highway at speeds with the H-10, good chance you can bend the top of an exhaust valve. Walt.0
terraplane8 wrote:Kdancy wrote:About to buy new plugs for the 37 Terraplane PU.
If your spark plug holes are carboned up, a thread chaser will clean them up nicely. Here in NZ "Total Tools" aka Trade Tools do a nice 14x18mm one for $13 + gst compared to an inferior one from Repco for $39.000 -
Don't know how you'd bend an exhaust valve unless your valves are already almost touching the head. The 1/2" reach plug in any case barely extends past the end of the plug hole into the combustion chamber.
On a planed 112 head fitted to my '36 Terraplane, standard cam and new thick valves there is plenty of clearance. The only possible issue could be that with a 1/2" plug the sparkplug tip is too close to the exhaust valve head which could cause the plug to overheat in extreme conditions?0 -
terraplane 8 You just dont give up! I think i will throw away all my shop manuals and just consult you. J-8 J-8 J-8 get it?0
Chuck G wrote:terraplane 8 You just dont give up! I think i will throw away all my shop manuals and just consult you. J-8 J-8 J-8 get it?
J8 that's what I thought too, until I put the heads all three of them on my bench and actually measured everything to my satisfaction. I ascertained that a 3/8" reach plug does not reach the end of the plug hole ending up with the spark occurring within the plug hole which is hardly conducive to efficient combustion. Who knows why J8 was originally specified, lots has changed since 1936 especially the fuel quality. All I'm saying is, taking a fresh look at something can pay off sometimes. Those who are interested don't take my word for it but check it out to see if it will work for you. My reason to use them was to improve efficiency, nothing else. The car goes like a rocket so something is right. Hill climbing is phenomenal, as good as the Terraplane Eight without actually measuring it.0 -
terraplane 8 sorry my comment was probably uncalled for and you do make some good points.We all want to improve our Hudsons and sharing info. here is a good place to start.0
Denzil, I'm willing to bet my reputation that you will find absolutely no difference in performance or economy between a 3/8 or 1/2" reach plug.0
- 102 Hudson 1916 - 1929
- 17 Upcoming Events
- 90 Essex Super 6
- 28.5K HUDSON
- 992 Street Rods
- 172 The Flathead Forum
- 75 Hudson 8
- 597 Vehicles
