will 46-49 carter fit 52 308?
hoggyrubber
hoggyrubber Expert Adviser
does anyone know if the carter wdo carb 1946-1949 hudson application will fit a 52 308? looks like the mounting base is same, what about throttle linkage and performance on the larger engine? thanks
  • GrimGreaser
    Yup, that's what mine had on it when I got it. Runs pretty good too.
  • Marconi
    Marconi Senior Contributor
    Everything should bolt/hook up, the only problem is the engine will be running too lean, read burned valves etc! Find the right carb and save yourself a lot of headaches, read money!
  • GrimGreaser
    Guess that works out for me, I need a relatively lean carb since most of my driving is at 5000+ feet.
  • hoggyrubber
    thank you both for the info. sounds like i need to save myself some headaches and money and get the right one.
  • hudsontech
    hudsontech Senior Contributor
    Carburetor you're looking for is WGD-776S - fits 1950-1952 all Hudson 6 exc Pacemaker & 8 Cyl. also fits 1953-54 Super Wasp & Hornet. That's for single - for Twin-H set up the carb is WA1-968S.
    Alex Burr
    Memphis, TN
  • hoggyrubber
    yes, the hunt is on for the wgd carb. some one put the smaller size one on my 308. it is frozen up and would need rebuilt anyway but i know now to not wast any time on it. i will just hunt for the right one.
