Weber Manifold
[Deleted User]
Have a gentleman across the pond wanting to buy a weber manifold or complete setup with carbs & linkage. Call at 309-968-6157 or email at maasfh@ntslink.net
Thanks Randy
  • mikeyb
    mikeyb Senior Contributor
    I have one... complete with Weber carb, single carb setup for stepdown, as an adapter that goes on the original manifold. I just have to find it... threw it off my car 4 years ago...
    Mike
  • dwardo99
    dwardo99 Expert Adviser
    Do you mean the kind that has 3 Weber side drafts? What kind of money is he thinking of spending? If that's what he wants, PM me.
  • Sent you PM. Thanks for your response.
    Randy
  • Sent you a message. Go see uncle.
    Randy
  • mikeyb
    Here is mine. I took it off my car because I wanted the original CARbureTER.
    Mike
  • Roger Harmon
    Roger Harmon Expert Adviser
    Mike,
    That's pretty cool looking. What size engine was it on? Did it run well?
    R/ Roger.
  • mikeyb
    Roger, that one was on my 308. The adapter was custom made for the original Hudson manifold. Id did run but the Weber is more tricky to adjust than the Carter. Plus, I wanted the original.
    Mike
