Reproduction Radiator Emblems
Old Fogey UK
Old Fogey UK Expert Adviser
I know that some people reproduce radiator mascots but are reproduction radiator badges available from anywhere ?
A friend here in England has just bought a 1933 Terraplane Six. His badge is missing from the radiator and he's asked me this question.
  • Marconi
    Marconi Senior Contributor
    Don't know about repro badges but I have a customer who restores the cloisonnet ones.
  • tigermoth
    tigermoth Expert Adviser
    cloisonne as in the '35 t-plane badges? if so could you provide the contact info? regards, tom
  • tigermoth
    i have not seen any repop '33 mascots. it would be interesting as to cost. i guess they would use a lost wax method. if they had a good original to work with it could be done. that is a detailed piece. regards, tom
  • Old Fogey UK
    The emblem on my '34 was spoiled by the chrome platers polishing it too much, so that it can't be enameled because the lettering is now very faint.
    As a stop-gap until I can find a nice one, I've used the white Hudson triangle emblem from the belt buckle available from the HET Store. I've superglued it to the mount on the grille. It's slightly curved which means it fits the mount's contours reasonably well. The sides of the triangle are about 1 1/2 inches long, so it looks about the right size.
    This emblem will only work on a 1934 Hudson, the shape of the triangle changed in 1935.
    Don't try to modify the shape of this buckle emblem. I tried to flatten one to make a fridge magnet but the enamel cracked and flaked when I applied pressure.
