What size cable?
I think #1 AWG is O.K. but before you go ahead find an old 6 volt cable and measure the cross section of the conductor and compare to #1 AWG.0
Having the heavier gauge cable is paramount for 6 volt systems. The reason that cars start better with the heavier cables isn't just because the stater turns the engine over faster. It is also because the cable has a low resistance and when starting, there is less voltage drop across the cable. This allows more voltage for the ignition system to function properly.
This is similar to the age old question regarding conventional "dry" clutch systems: "My pressure plate went out- should I replace the clutch disk while I'm at it?" YES! The disc may still have some wear left, but getting at it is the hard part, so while you're in there, replace the disc.
If you have perfectly good 1 guage cables, it probably isn't worth the expense to make up new ones. BUT if you have to make up new cables anyway, by all means, go with the 1/0. There is no "overkill" in 6 volt wire size, and the difference in cost will be minimal.0
- 115 Hudson 1916 - 1929
