Really stressing
Majumbo
Majumbo Expert Adviser
Hello I got my head gasket and put it on the motor with the head but I used the torque sequence from a 49 brougham on accident instead of from a wide 262. Do you think I will be okay or am I screwed. I really don't want to spend another 75 dollars on a head gasket.
Please help I'm stressing bad!!!
  • Marconi
    Marconi Senior Contributor
    You should be O.K. with that. I think both engines have the same bolt pattern/number of head bolts and the same size bolts, therefore the same torque settings. After all, all they did was to widen the block 1/16" to enlarge the water jacket. Basically, you start with the center head bolt and work outwards in a widening circle.
  • Majumbo
    I did middle bolt out through the center. Then the middle out through the passenger, then middle out through the driver
  • Majumbo
    Lol looking back on my previous message I realized I probably didn't make much sense. The torque sequence which was supposedly off of a brogham was start in the middle section if the middle bolts. And work out then do the same thing for pass the. Driver side
  • Majumbo
    If you follow this link it will show what sequence I did.
    http://www.classiccar.com/index.php?option=com_kunena&func=view&catid=13&id=131280&Itemid=152#131368
    What sequence is this? It's different from the factory. I only torqued to 65
  • I posted that its a factory note on an updated procedure for torquing a head down.
