COIL
TOM-WA-
TOM-WA- Senior Contributor
I need to replace the coil on my 54 262 engine..
Does anyone have a replacement number and possibly where I can get a
6v Coil for my car?
THANKS
TOM
  • Tom, check your PM
  • hudsontech
    hudsontech Senior Contributor
    From the information I have the original coil number is CA-6012A and fits 1950-1954 all Hudson. There is a NAPA generic coil, but I don't have that number to hand.
    Alex Burr
    Memphis, TN
  • Last time I bought a 6 volt positive coil was from NAPA. Number C-7. I assume they still sell them.
  • Marconi
    Marconi Senior Contributor
    A generic 6 volt replacement coil will work fine, just make sure the pos. terminal goes to the distributor and the neg. goes to the ign. switch.
  • Geoff
    Geoff Senior Contributor
    Or you can buy a 12 volt coil that is specified for use with an external ballast resistor. These work just fine on 6 volts, without the resistor of course.
