cardboard for parcel shelf 54 Hornet Hollywood
I am wondering if anybody has made or could tell me how to bend the paneling for the parcel shelf in our hollywood.It is very narrow and has different curves this holds the vynal that goes below the rear window. and is there any special sequance to install the side windows in our car. Hudsonly Ray:woohoo:
Go to a good auto upholsterer and ask for, I think it's called chipboard, it comes in different colors. Cut to size and shape and dampen with a spray bottle on the back side. Clamp or weight down in plac and wait for it to dry, overnight, when dry you should be able to glue it down or use whatever mechanical fastners they used to attach it.0
Wow one I can answer
Contact Restoration Specialties http://www.restorationspecialties.com/
purchase waterproof panel board
cut board to size
draw out the bend lines
using a straight edge to guide the non sharp (back) edge of a razor knife to crease the board along the inside of the bend
carefully, using the steight edge as a guide, bend the board along the crease
i
sometimes, the thickness of the board will require a slight cut on the along the line on the outside of the crease
also, you might have to reverse the crease and cut to get a smooth bend
practice with the excess before trying on the needed part
this board then be covered with vinyl as original tbis board can be stitched through to attach the perimeter bead
hope tbis helps
lew mendenhall0 -
Thanks Lew and Marconi My nephew just has the bottom half of the door inner panels to do and ods and ends of vynal besides the parcel shelf cardboard. and he will be finished all the seats and door panels .I still have to find several smooth ss strips that cover the cloth and vinal.where they meet. I bought a ready made headliner and carpet set from SMS auto fabric. That is who reproduced the Brown cord cloth material that I am using.It is comming.:woohoo: :woohoo: :woohoo: :woohoo:0
Lew,
Sounds great! How thick is the Restoration Specialties panel board? Their catalog doen't give any dimensions on thickness. Thanks, WaltLA0 -
Walt about 1/8 inch0
Lew,
Thanks! Not for package rack but doors and kick panels does anyone have experience with Luan (Spp?)- a mahogany like plywood available in something close to 1/8 inch, or Masonite? Both might need waterproofing, especially on edges. Upholsterers in this area are using them. WaltLA0
- 104 Hudson 1916 - 1929
- 172 The Flathead Forum
- 599 Vehicles
