Another Brake/Clutch Pedal Question
Unknown
It seems the money I spent on Hudson Manuals was a waist at this point since I cant find any answers there!! Thank goodness for you guys on the forum! The previous owner converted my hydromatic to a manual, and now I am converting back, and trying to remove the clutch pedal. Removed the master cylinder and everything attached to the brake pedal. QUESTION- How do I get the brake pedal and clutch pedal off??????? Pic attached is where I am at!
[attachment:1]DSC00419.JPG[/attachment]
Thanks for all your help
Brian
  • Lets try the pic again!
  • SuperDave
    SuperDave Senior Contributor
    Me thinks the "Gas Wrench" would work here.. LOL But I have been accused of being impulsive. You don't plan on useing them again are you?
  • Well,,, I am swapping out steering columns and possibly brake pedal along with master cylinders, so possibly!! I would like the practice, so I would prefer to get it out the nice way!!!
  • This is the other side connecting to the clutch pedal. Is the pin that you see actually a bolt that has miraculously lost its head, or an actual pin??
  • Geoff
    Geoff Senior Contributor
    I have only worked on r.h.d. cars, but to me it looks like you need to drive out that taper pin from the hub to get the pedal arm off.
  • Well the pin didn't work and I got a little IMPULSIVE- Thanks Dave- so I just ended up cutting it off!!!!
    thanks for the suggestions guys!!
    Brian
