Power brake pedal pad wanted for 54 Special
Unknown
edited September 2011 in HUDSON
Am looking for a power brake pedal pad for my 54 Special. Have tried Albright's and Paul Schuster. There must be one out there somewhere in reasonable condition.
Doug
  • Doug, I have been looking too. The only thing that I have come up with so far is, if we can find a 55,56,or 57 with power brakes, then these vehicles might have what we are both looking for. This is based on the fact that the 54 through 57 have the same type of Power Brake units. So they may have the same brake pedal.
    I have been looking and so far no luck on this end. If you find one of the cars I indicated and it has what we are looking for please send me an e-mail. Good luck.
    Rich Smithen
    jonme2@wildblue.net
  • PAULARGETYPE
    PAULARGETYPE Senior Contributor
    THE PEDAL WE ALL ARE LOOKING FOR SAYS POWER BRAKE ON THE PEDAL I'M WORKING ON GETTING SOME MADE BUT THIS TAKES TIME IT WAS 6 TO 7 MONTHS TO GET THE 55 TO 57 GAS PEDALS MADE I'M WORKING ON A MOLD I'LL KEEP EVER ONE POSTED
  • nick s
    nick s Senior Contributor
    its different than either of the ones mentioned it is 4.17 x 2.7 on the outside and has about .75" corner radii. does not say power brake nor does it have the grove on the side like the metro. I think press kale (maybe it was full line) used to sell the 55-57 and said it would fit the 54, i opted for the best original i had. attached is a picture of an original
  • Ken, I need some clarification about the pad that you referenced. The dimensions of the metal part of the power brake pedal is 2 and 5/16 tall, or vertical as it is in the car, by 3 and 11/16 wide. It seems that the pad you referenced would be too big. ? ? ?
    Doug
  • PAULARGETYPE
    OK OK I WENT DOWN THE GARAGE AND LOOKED I DO HAVE 1 USED POWER BRAKE PEDAL PAD THATS FOR A 54 HUDSON WITH POWER BRAKES AND I HAVE 1 USED 55,56,57 POWER BRAKE PEDAL PAD DOUG YOU NEED 014 I'M ALMOST SURE SEND ME A EMAIL AT HUDSON1957@AOL.COMHET DROP THE HET OR CALL I'M IN THE ROSTER
