Sweden hornet update wiring harnes
Maybee you have follow my Sweden Hornet Update .Now i´ts time to do new wiring harnes to my sedan at the same time i gone convert it to 12 volt but all my old harnes is in bad condtion so it hard to see . I make the new harnes after the Wiring Diagram in the part book but there is no diagram over the director indicator there are a block there the dir ind. lever harnes go but i dont know who others wiring to connect .
Can somebody help me is there any wiring diagram avelible for the dir. ind . ?
and i be glad if i get tip of 12 convert.
Jan Pettersson Sweden
Jan the wiring diagram in the shop manual does not include the wiring for the turn signals because they were usually added on aftermarket even if done by the dealer. If you look up "SIGNAL-STAT wiring diagram" in google I think you can locate a wiring diagram that is just for add-on turn signals. It should be accurate but if not you may have to look up instructions/diagrams from the turn signal manufacturer.0
