Wiring for a Hudson Hornet
Should be identical to what they have listed for '51 & '52.0
I have used their harnesses many times. Never any problems. There are some parts you can fab for yourself. I would buy the main dash harness and make all other wiring myself.0
Or you can try Y&Z wiring.0
Got mine from Naragansett Reproductions. Evrything fit perfectly, very clear instructions. Good communication from them. Good response to dummies like me who is easily confused. They are a family run business and have a website.
Just to give some more choices,
Kim0 -
any web site address?i'll be needing a wiring harness..i was gonna go with a Rebel Wiring harness for a street rod.0
Rhode Island Wiring makes exact replacements and it comes with easy to follow directions.
Roger0 -
51 will be slightly different as the switches were moved in 52RL Chilton wrote:Should be identical to what they have listed for '51 & '52.
having worked with both - unless they have changed, Y&Z is inferior to the rhode island product for two reasons: 1st they do not follow the hudson colors and second they are not clearly marked. both have quality wire, looms and terminations.0
