Wiring for a Hudson Hornet
Unknown
Time for new wiring. Rhode Island Wiring shows wiring for most stepdowns other than 53 (!) for some reason. Anyone use their product for a 53? Any other suggestions. I have used Rhode Island for my 34 Dodge, and it was awesome.
  • RL Chilton
    Should be identical to what they have listed for '51 & '52.
  • I have used their harnesses many times. Never any problems. There are some parts you can fab for yourself. I would buy the main dash harness and make all other wiring myself.
  • Nevada Hudson
    Nevada Hudson Senior Contributor
    Or you can try Y&Z wiring.
  • kamzack
    kamzack Senior Contributor
    Got mine from Naragansett Reproductions. Evrything fit perfectly, very clear instructions. Good communication from them. Good response to dummies like me who is easily confused. They are a family run business and have a website.
    Just to give some more choices,
    Kim
  • chopperchuck
    chopperchuck Expert Adviser
    any web site address?i'll be needing a wiring harness..i was gonna go with a Rebel Wiring harness for a street rod.
  • Rhode Island Wiring makes exact replacements and it comes with easy to follow directions.
    Roger
  • nick s
    nick s Senior Contributor
    51 will be slightly different as the switches were moved in 52
    having worked with both - unless they have changed, Y&Z is inferior to the rhode island product for two reasons: 1st they do not follow the hudson colors and second they are not clearly marked. both have quality wire, looms and terminations.
