Water pump sources
Dale Cooper has water pumps, engine gaskets, seals and engine rebuild parts for a lot of engines 1914 to 1957. All gaskets are either new or N.O.S., all cork and paper gaskets are new manufacture. He has bearings, valves guides and springs, timing components, pistons and rings (some original pinned piston rings) , lifters, oil pumps & kits, thrust washers and crank spacers for vibration damper 1931-56 6 and 1934-52 8. Catalog is viewable online at http://www.hudsonmotorcarco.com
For snail mailed copy of catalog or order Dale Cooper, 7444 Vine and Paddock, Cincinnati, OH 45216-1712 or call (513) 821-6200 .0 -
some other sources as well--
http://arthurgouldrebuilders.com/
http://powersteeringparts.com/water_pumps.htm
http://cgi.ebay.com/ebaymotors/1948-1956-Hudson-6-Str-8-Precision-Rebuilt-Water-Pump-/200545612934?pt=Motors_Car_Truck_Parts_Accessories&hash=item2eb1733486These are precision rebuilt by Rebuilder's Choice and are guaranteed for the lifetime of your engine.
http://user.cavenet.com/tmac1/miscellaneous.html0 -
Thanks for the info. Does Albright's still have reman water pumps?0
Just talked to this owner on the phone. Uses modern bearings and seals, not Chinese made, around 100.00 for a water pump. Been in business for 30 years. I think I will give him a shot on the next one I have done.
http://www.waterpumpman.com/0 -
Got mine from Dave Kostanzek (check WTN) but he is finishing up his stock and then is done with them. Dale Cooper is a super fair guy; I'd give him a call.0
- 115 Hudson 1916 - 1929
