Hi, just joined, looking for info.
[Deleted User]
Hi, Bob from Ponoka, Ab. I found this recently in the bush literally in my backyard... Just wondering what year it might be? Its pretty beat up, but motor is there, both axles, frame is really rusty. I wonder what the motor is?
  • hudsonsplasher1
    hudsonsplasher1 Senior Contributor
    Welcome to the forum. It looks like a 38 Terraplane coup to me. The engine would be a flat head 6 cylinder.
  • oldhudsons
    oldhudsons Senior Contributor
    the grille & front fender look non-Hudson to me
  • nick s
    nick s Senior Contributor
    I thought 38 Hudson 112
  • Val
    Val Member
    Not sure if it is a hudson but if so I would say 1938. But the grille doesnt lok Hudson but not seeing it it's hard to say
  • Geoff
    Geoff Senior Contributor
    My guess is 1938 H112. The give-away is the handle on the side. This was the only model that had that.
  • hudsontech
    hudsontech Senior Contributor
    Another means of ID is, if you can get the door open, check the right side door post above the hinges, for a metal tag with model and serial number - that'll tell you if it's a Hudson or Terraplane. Or whatever.
    Alex Burr
    Memphis, TN
